Hello I have a question about compatibility. I bought 16 gigs of this ram https://www.amazon.com/gp/product/B006YG9EEW/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1 about a year ago for my amd motherboard. I want to upgrade from my fx 6300 to a i5 6600k or possibily an i7. What motherboard do you suggest I buy and will it work with the ram I purchased before? I'd hate to buy more, kind of on a budget. Thanks so much ;)
https://linustechtips.com/topic/712065-need-help-with-getting-right-mobo/
As far as I know the new Skylake boards like the z170 take ddr4, not ddr3.
Welcome to Maryland.
We have crabs.
22 minutes ago, johnny5c said:
You're limited on choices but there's a few,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157652
Just make sure it supports actual DDR3 and not just DDR3L.
I'm looking for a bit cheaper about the 90 to 100 range? Or would it be worth just buying DDR4?
You're going to want a Z170 board to go with your unlocked 6600k and there's only a couple that support DDR3,
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132574
Personally I would either save up a bit or sell your old hardware and go with DDR4.
