Hello all,
My problem is that upstairs where I spend most of my time I get a very weak WiFi signal on all devices. My hub is downstairs and can't be moved and I know there is a range of wireless access points out there but I don't know what would be suitable for my situation. It would also be preferred if I didn't have to run long cables from my router upstairs. I have a basic understanding of things in this area but am not sure what would be the best way for me to go about resolving it. So my question to you people is: what is an affordable lets say WAP that will work well in the home environment where it doesn't need to be capable of long range (maybe 12ft radius most)?
Edit: P.S. I'm new to the forum so I apologise if this is in the wrong forum
Thanks in advance,
Zack
https://linustechtips.com/topic/711932-weak-wifi-how-fix/
Powerline is a substitute to running cables, as for access points, try the AC lite or the AC LR from ubiquiti
--- Purple Prime ---
i7 8700k + Hyper 212 Evo | MSI Z370 Gaming Pro CarbonG-Skill Trident Z 3000Mhz RGB 16GB | Gigabyte Aorus GTX 1080ti
Crucial MX500 500GB | WD Black 2TB | Corsair RM850i | Fractal Design Define R4LG 27UD68-P | Logitech G502 + G910 | Windows 10 Pro
--- Proteus Server ---
AyyMD Ryzen 5 3600 | Asrock B450m Pro-4 | Crucial Ballistix Sport LT 32 GB (2 x 16 GB) | Sapphire RX570 NITRO+ 8GB
Crucial MX500 1TB + Samsung Spinpoint F4 2TB + Seagate 1TB 2.5" + 5TB iDrive  | Windows 10 Pro (Temporary)
--- Camera Stuff ---
Canon EOS 77D | Canon EF-S 18-55 f/4-5.6 IS STM | Canon EF-S 55-250 f/4-5.6 IS STM | Canon EF 50mm f/1.8 STM
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/711932-weak-wifi-how-fix/#findComment-9085685
Eero? It's expensive, but you can have even coverage across your whole house.
Quote me to see my reply!
SPECS:
CPU: Ryzen 7 3700X Motherboard: MSI B450-A Pro Max RAM: 32GB I forget GPU: MSI Vega 56 Storage: 256GB NVMe boot, 512GB Samsung 850 Pro, 1TB WD Blue SSD, 1TB WD Blue HDD PSU: Inwin P85 850w Case: Fractal Design Define C Cooling: Stock for CPU, be quiet! case fans, Morpheus Vega w/ be quiet! Pure Wings 2 for GPU Monitor: 3x Thinkvision P24Q on a Steelcase Eyesite triple monitor stand Mouse: Logitech MX Master 3 Keyboard: Focus FK-9000 (heavily modded) Mousepad: Aliexpress cat special Headphones:  Sennheiser HD598SE and Sony Linkbuds
https://linustechtips.com/topic/711932-weak-wifi-how-fix/#findComment-9085712
I've the Ubiquity ones and these are great.  2 ap's cover the whole house.
Laws only govern the honest.
https://linustechtips.com/topic/711932-weak-wifi-how-fix/#findComment-9085728
Getting my AC LR soon :D
Zoom H5 + XY-5
Phone - Oneplus 6T
https://linustechtips.com/topic/711932-weak-wifi-how-fix/#findComment-9085744
