Hey guys, So here is my issue, I have an Intel Core i7 6700K @4.5ghz @1.39v installed into a MSI Z170A Krait Gaming 3X, Now here is the issue.... I need to increase my CPU current limit.... But now here is the tricky part, I already have it maxed out and what it is doing is when i run a stress test it drops back down to the stock clock (4.0GHZ) but the voltage does not change or anything nor do the temps.... So i was wondering if i could make it more than what the motherboard can do or is there another issue? I have tried uninstalling and reinstalling the CPU, RAM.... Basically everything.... I have even reinstalled the Power supply and the graphics card.... My power supply is a Corsair RM 650X Fully Modular Gold Certified 650W so it has more than enough power then what it needs.... I have also tried increasing the max TDP to 150W for the I7 6700K... I am very confused about what to do? Could anyone help me out? Thank you. :)
Current PC: "For Now Because I Have A Habit"
CPU: Intel Core I7 6700K @4.5Ghz
Motherboard: Asrock Z170 Extreme4
RAM: 16GB G.skill TridentZ 3200Mhz DDR4
CPU Cooler: Thermaltake Water 3.0 360 Riing RGB Edition
Graphics Card: Nvidia Geforce GTX 1080Ti Founders Edition MSI
Case: Limited Edition Thermaltake View 31 Riing RGB
Power Supply: CoolerMaster V750 Fully Modular
SSD: Kingston HyperX Savage 240GB
HDD: 3TB Toshiba 7200RPM
Peripherals:
Monitor: AOC U2868PQU 4K 28" 60HZ
Keyboard: G.Skill Ripjaws KM780 RGB Cherry MX Red
Mouse: Razer Deathadder Elite
Mouse Pad: Razer Goliathus Speed Extended
Speakers: Creative SBS A250
Headphones: Razer Kraken Pro 7.1
https://linustechtips.com/topic/699155-how-to-increase-cpu-current-limit/
Also it is not the Temperatures because they only get up to 80 degrees C.
Peripherals:
1 minute ago, APasz said:
Sounds like you have a chip that doesn't want to go any faster. If you've already maxed everything.
That is not the problem.
Peripherals:
1 minute ago, RKRiley said:
If its hitting 80C it could very well be throttling back down to 4ghz.
So that is the issue?
Peripherals:
Just now, Generallee said:
It shuts off at 105c, throttling starts way back in the 80c range
Has it changed. Used to be that it start throttling at about 100c then do a compete shutdown at about 120ish depending on model. This 80c limit is news to me. Do you have a source for it?
-アパゾ
Okay so now this is very weird.... It is NOT thermal throttling because it still does it at STOCK with absolutely NOTHING done to the BIOS, Even without XMP.... I even rebuilt the computer AGAIN! Please someone just help me! I know it is not thermal throttling because it still does it at stock which only hits 68 degrees C. I quoted all of you so that you would read.
3 hours ago, RKRiley said:
It /could/ be, im not sure what the limits are on the 6700k though, but it does seem high enough to start throttling.
Peripherals:
8 minutes ago, SLIClocker said:
~snip~
If you've already maxed everything out, there isn't really anything we can do. Some chips simply wont go above a certain speed.
Take my cpu 4770k for example. I should able to get it up to 4.5 without any problems but I can't get it over 4.0 without introducing stability issues. I was unlucky, there isn't anything I can do about it.
Now if you've gotten this chip to 4.6 but now you can't then yes you have a problem. If this is the first time trying 4.6 and it fails, nothing you, me or anyone can do.
-アパゾ
I think the last thing you want to do is circumvent the CPU's current regulation. That sounds like a profoundly terrible idea. If there's truly an issue with the amount of current the CPU is getting, that sounds like a defective motherboard and/or CPU which should be RMA'd. If it's just that you're at nearly 1.4 V and still can't keep 4.5 GHz stable, that sounds like a poor result from the silicon lottery.
