Hey guys I have to sticks of adata xpg ram 2800mhz and I was in the bios and saw it was set to 2100mhz so I put it back to 2800 and now my computer won't boot up it only shows A2 On the side.. My motherboard is a msi x99s sli krait edition
RIG: CPU: i7-5930K 4.5GHz GPU: EVGA GTX 980 TI Superclocked 6GB RAM: 16GB DDR4 Motherboard: Msi X99S SLI Krait Edition Storage: 128GB SSD 2TB HDD
https://linustechtips.com/topic/694519-pc-wont-start-ram-problem/
Turn the psu off and remove the battery on the motherboard for a few minutes. Turn the power button on to remove any lingering power in the system them out battery back in and boot
Main system:
i7 6700k @4.8ghz 1.45v
ROG Maximus Hero VIII
Gigabyte G1 980ti Sli @1500 ghz
Samsung 950 pro 512gb
16gb G.Skill Ripjawz V @3400mhz
Corsair H115i 280mm AIO
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Intel i3 6100 @4.6ghz 1.52v
Asrock B150M Pro4/Hyper
Intel 750 series 400gb
Radeon Rx 470 XFX
Thermaltake Water 3.0 360mm AIO
inWin 303 case
AMD Phenom II x4 940 @3.9ghz 1.65v
Gigabyte 780g mobo
Corsair H100 240mm AIO
Corsair Dominiator 8gb DDR2 @1066
Evga GTX 750ti FTW @1450mhz
Thermaltake Matrix case (modded)
"The best way to look stylish on a budget is to try second-hand, bargain hunting, and vintage"
The problem it you probly set the ram @2800mhz with the 2133mhz timings.  That or your ram requires  more voltage @2800
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
I just set it back to normal
Its not hard to get it to run at 2800mhz if you want help with it?
Main system:
Corsair 400c Case
Corsair RM1000i
Backup/Older/Toys:
Radeon Rx 470 XFX
inWin 303 case
Gigabyte 780g mobo
Yes plz
Clear cmos?
