So lets start my problem from "last" setup
CPU amd phenom x6 1090t
GPU 560ti
MOBO asus m4a77t (some random, at point when im buy that setup just need support cpu)
RAM some random 8gig kingston 1333
HDD wd black 1tb for dump stuff, + 1 old 250 gb hdd for boot^
PSU 850watt (yea i know that overkill but i have that for rlly nice price)
monitor 1920x1080
The main game what I'm playing - World of Tanks
get on avarage setting without stream or xsplit run 60+ fps
just start xsplit = drop my fps to <45
start stream drop even more
ill try upgrade cpu/mobo and add some capture card
"little" upgrade was:
CPU - 3770k @4.2 got (~60 degree on full load with prime95)
mobo - mpower z77
capture card - avermedia live gamer hd
now i can run game on ultra settings without stream and get ~80+ fps
run xsplit with no drop in fps
start stream on ultra i got <15 drops and its not what im whanna
for normal stream+game fps need change setup to avg-high (and even some effects just off, water tree and grass)
setting for the xsplit problemsw.jpg for source im using avermedia. and encoding with my cpu
stream runs only at 720p 25fps cuz when im set it to 1080 then im can't play even with avg setups
and last part is... what I need do/change for improve fps and stream quality?
soz for my bad english
https://linustechtips.com/topic/6921-need-some-advice-help-with-pcxsplit/
