So, my pcpartpicker wont load. Sorry about that. I am planning on a build with mostly used parts. Here is a google sheets since that is better than nothing. Also, I need some ram from somewhere. Reply here if you have any:
Here is the sheets:
https://docs.google.com/spreadsheets/d/1-PNsvViPt5mWY4dsirC8Q1bul8XclKRFg--pW5AAFQY
i like trains 🙂
https://linustechtips.com/topic/691986-first-desktop-build/
If you are paying $180 for a sandy bridge CPU, you are getting overpriced. the cyrorig is decent, so thats fine. also why are u spending so much on fans? just buy a value pack in amazon, you will be fine
AMD Ryzen 7 7800X3D | Sapphire Pulse AMD Radeon RX 7900XT Triple Fan | G.Skill 32GB 2x D5 6000
https://linustechtips.com/topic/691986-first-desktop-build/#findComment-8874934
I meant $80. That saved me a lot of moneys.
i like trains 🙂
https://linustechtips.com/topic/691986-first-desktop-build/#findComment-8874953
Oh, then you got a solid ass deal. There was this one Tom's hardware thread where they said Sandy Bridge was the holy grail of CPU overclocking.
https://linustechtips.com/topic/691986-first-desktop-build/#findComment-8874961
It is already at 4.2ghz. I don't want to mess anything up, so I'm going to leave it there for a while
i like trains 🙂
https://linustechtips.com/topic/691986-first-desktop-build/#findComment-8874969
no balls, but you got brains
https://linustechtips.com/topic/691986-first-desktop-build/#findComment-8875022
I'm using the CPU now at 4.2 stable. I had it at 4.4 but I think the BIOS update de-stabilized it a bit (somehow). I was able to touch 4.7 with it but it would crash. I was able to narrow down that either the motherboard or the PSU was not capable of running the CPU at 4.7 (leaning towards the motherboard as it was a budget overclocker).
Intel Xeon 1650 V0 (4.4GHz @1.4V), ASRock X79 Extreme6, 32GB of HyperX 1866, Sapphire Nitro+ 5700XT, Silverstone Redline (black) RL05BB-W, Crucial MX500 500GB SSD, TeamGroup GX2 512GB SSD, WD AV-25 1TB 2.5" HDD with generic Chinese 120GB SSD as cache, x2 Seagate 2TB SSHD(RAID 0) with generic Chinese 240GB SSD as cache, SeaSonic Focus Plus Gold 850, x2 Acer H236HL, Acer V277U be quiet! Dark Rock Pro 4, Logitech K120, Tecknet "Gaming" mouse, Creative Inspire T2900, HyperX Cloud Flight Wireless headset, Windows 10 Pro 64 bit
https://linustechtips.com/topic/691986-first-desktop-build/#findComment-8879334
