8 hours ago, zMeul said:
does it goes down after a reboot?
if yes, one of the drivers is leaking RAM
nonpaged pool is RAM reserved to the OS kernel
one other thing: did you disabled page file?!
Yes, after i do a reboot it goes down. but when time passes it goes up again. How can i foudn out which of the drivers is leaking?
https://linustechtips.com/topic/675300-memory-leak-i-think/#findComment-8697332
3 hours ago, raider009 said:
I do have a Killer network interface onboard (i got a MSI gaming Z97a MOBO) but not a killer expansion card
same thing
uninstall every Killer app except for the driver itself
Quote
there isn't a true tested way to find exactly the culprit
what you can do is to clean install Windows, start installing drivers, from chipset to video card drivers without the extra shit it's bundled with and observe the behavior, then install the network, then the sound drivers - observe
one other thing to do: go on to the component's manufacturer website (not on MSI's) and find the most up to date driver for that component and install it; also a BIOS update won't hurt
https://linustechtips.com/topic/675300-memory-leak-i-think/#findComment-8698094
