(This is a repost)
I am sitting here trying to install a second pc. After the installation of windows I cannot connect to the internet. I download drivers to the motherboard on my other pc and transfer them to the new pc via USB. 3 out of 4 drivers install, the one which is called Realtek LAN doesn't. So basicly the one i need. Whenever i try to install this driver i get the error: The Realtek Network Controller was not found. If Deep Sleep Mode is enabled Please Plug the Cable. I googled around a bit and people suggested that removing the powercable and RAM stick for a few minutes would do the trick, but it has not. The motherboard is a GIGABYTE GA-P61-USB3-B3 and I am usibbg an old 2 gb dominator ram stick from corsair.
Any help is appreciated!
If the driver from the manufacturers website does not work, try one from realtek directly.
Also, did you make sure the Network controller is enabled in BIOS ?
Also, does the device manager show you a device or two without drivers?
Other drivers did not work. I cannot find the Network controller enabling in BIOS and this picture is what info i have about the device (I think...?)IMG_0874.JPG
The installer shows the error whenever it tries to " Detect Realtek ethernet network card and cable"
