Hey! So I have an evga 500+ and I was playing a game when it shut down randomly I booted it back up and my mobo reported a psu surge. I don't know how it happened, I think it might've been cause when I was playing the game I paused for a sec to tighten a thumb screw that I needed to tighten but was too lazy to do it until then, I'm thinking it was static from my clothes or something else, I was able to boot windows OK and it seemed OK after that. Any ideas?
Delta R5 Build
CPU: AMD RYZEN 1600 Purchased
Motherboard: ASUS PRIME B350-PLUS  Purchased
RAM: Corsair Vengeance 16GB DDR4 3000MHX (2X8GB) Purchased
CPU COOLER: DeepCool GAMMAXX 400 GT RGB Purchased
GPU: Gigabyte Xtreme Aorus 6gb GTX 1060 Purchased
Case: NZXT S340 (White) Purchased
PSU: EVGA 550B3 Purchased
HDD: WD Blue 1TB  Purchased
SSD: Sandisk SSD PLUS 120GB Purchased
Wifi Card: Asus PCE-N15 PCI-E 1X Purchased
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/
So I should be fine considering it's a new mobo?
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653265
5 minutes ago, Comic_Sans_MS said:
What is the PSU? EVGA has a lot of PSUs and a couple of lines have a 500W model.
500+ basic 80+
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653267
Just now, DisconnectedYT said:
if its not like a super cheap budget thing that you got for $60 then you should be fine.
My Mobo is $250 i think and it fine ( i think....)
It was priced at 69.99 and I bundled with a CPU so my store took off 40$ ?
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653279
1 minute ago, Comic_Sans_MS said:
What is it powering, your "build" in your signature really isn't helping me at all
OH sorry for that it's a build I just did so i haven't yet updated my signature
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653287
$250AUD, not $250 USD.
You have a bomb of a PSU which should not be powering a computer and you don't care which is fine, but  you are derailing a thread about someone who is having a problem and is legitimately concerned about their PC.
I just looked at your profile, you should probably upgrade the PSU to something like a Corsair CX, XFX XT or EVGA B, that said a better PSU like the Corsair CX 450/550/650M, Vengeance, RMi/RMx/HXi, EVGA G2, B2, GS, GQ, Anything from Seasonic or XFX and the Antec High Current series would also be fine.
That said your PSU shouldn't be surging, it may not be great but it shouldn't be out of specification, that said I have also heard that certain ASUS motherboards surge detector is often wrong.
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653313
I just looked at your profile, you should probably upgrade the PSU to something like a Corsair CX, XFX XT or EVGA B, that said a better PSU like the Corsair CX 450/550/650M, Vengeance, RMi/RMx/HXi, EVGA G2, B2, GS, GQ, Anything from Seasonic or XFX and the Antec High Current series.
So, your point is, my PSU isn't the best and eh I just don't want to kill anything so I'm guessing everything is fine considering it booted correctly? PS updated my signature ;)
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653320
A PSU is a PSU, ive never had a problem with my $50 WideTech Firestarter.... see what i did there ;3
only error ive every got was a one off power surge.
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653325
Oh, so my psu just had a small slip up, that's all? I was worried I already broke something lol.
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653336
The computer booting doesn't mean that it is fine. The EVGA W1 is not great, that said if it is working normally it shouldn't be damaging your components.
A PSU is not just a PSU, it is what is powering your system. If it has bad ripple it CAN damage your computer. It CAN kill your computer when its dies it's short life, it can slowly kill your computer and your PC parts will die a lot sooner than expected. The EVGA W1 may not be great, but it is still a real brand and is can be fine for some computer, unlike widetech which is not listed on the hard tech x PSU data base or more importantly, not on 80plus.org.
Do you know what a Surge is? If so, why do you think it is nothing?
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653362
4 minutes ago, DisconnectedYT said:
well if it keeps doing it then you have a problem, but if this is the only time its happend then it must just be a one off.
Ok. Cool I'll bump the thread later once I confirm tomorrow that my PSU just had a small slip up
Delta R5 Build
--BUILD READY--
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653363
A PSU is not just a PSU, it is what is powering your system. If it has bad ripple it CAN damage your computer. It CAN kill your computer when its short live dies, it can slowly kill your computer and your PC parts will die a lot sooner than expected. The EVGA W1 may not be great, but it is still a real brand and is can be fine for some computer, unlike widetech which is not listed on the hard tech x PSU data base or more importantly, not on 80plus.org.
A one off power surge could kill your PC but the chances are so minute that its not worth it.
If my PSU did kill my PC then under warranty i would get everything covered and when its outside of warranty i know it still wouldn't kill my pc as yes its crap but ive taken it apart and it looks to be well built.
Edit: And if your Mobo is good enough they have Surge Protection. Every Z97 MSI Mobo has very good surge protection. My house could get hit by lightning and nothing would happen.
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653376
Only the 500 W1 and the 500B which are both not great
I can guarantee that it wasn't static from you, your case is connected to the ground path on your motherboard, which goes to your PSU's ground path which goes to the ground. A PSU surge must have come from a surge from outside (from your AC mains), and if you live in a place that has unstable AC power you'll want to upgrade that PSU to something better. A surge protector will help as well (do connect everything that plugs into your computer into it, that means router, monitors, speakers and etc).
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653419
Yes you might be able to claim your PC parts by warranty if your garbage Vic market brand PSU blows up your computer, but is it fair that you are risking your computer which is $800+ on a "fire starter" and you are getting someone else to pay for it (assuming they agree to replace it, which they may not since it was the user's fault), Power Surges are a jolt of high voltage electricity going through a lower voltage line, your VRMs on your motherboard, GPU, HDD and SSD may not be able to handle the garbage power since it only have to be able to handle the very little ripple aloud in the ATX specification for normal operation.
I wasn't sure if the BQ was 500W or 550W, but that said a couple is around or is 2.
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653469
BQ only is 650W, 750W and 850W as of today.
Computer Specs:
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653493
Is the EVGA product line
N1 < W1 < NEX-B = B1 < BQ < NEX-G = G1 < B2 < GQ < GS < G2 < PS < P2 < T2 ?
N1?
I would say, 400W < 430W, 500W < 450B, 500B, NEXB < 600B, NEXG, G1, BQ < B2, GQ, GS, 1000G < G2, PS, P2, T2
I think I didn't miss any. As you can see a lot of units just are so good that they're not much better than the others.
Computer Specs:
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653531
38 minutes ago, Energycore said:
N1?
Non certified 400W PSU
http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=436
https://linustechtips.com/topic/671259-pau-surge/#findComment-8653658
