36 minutes ago, Shoumic said:
Hey,
Do you guys think the S340 would be a good case for a GPU like the GTX 1080? How is the airflow in the case? Will it be cool on the inside? Don't really mind much noise if there's any.
Every review I have heard of the s340 has been 5/5, top notch kinda case.  I think you are fairly limited with radiator positioning, but there are four mounts of case fans which should be able to provide plenty of airflow to cool a 1080
https://linustechtips.com/topic/670909-nzxt-s340-question/#findComment-8649510
The S340 is a great case, will have no problems with a 1080 or really any gpu.
May Our Framerates Be High And Our Temperatures Be Low.
PSUs: EVGA B2/G2/GQ/GS, Corsair RMx/i, Grey-Label CXM, Everything Seasonic/Delta/Super Flower, XFX except XT
Use pcpartpicker.com
https://linustechtips.com/topic/670909-nzxt-s340-question/#findComment-8691934
  • 4 weeks later...
