I am getting a dell inspirion 7559 for Christmas and found two variants for the same price. I was wondering should I get variant 1, gtx 960m, Corri7 6700hq ( quad core 2.6 ghz to 3.6ghz )8gb of ram and a 1tb hard-drive or, variant 2, gtx 960m, Corri5 6600hq ( quad core 2.3ghz to 3.1ghz ) 8gb of ram, a 1 Tb hard-drive and a 256 gb ssd.
https://linustechtips.com/topic/669645-laptop-choice-help/
http://laptopmedia.com/highlights/intel-core-i5-6300hq-vs-intel-core-i7-6700hq-which-is-better-for-gaming-and-is-it-worth-the-extra-bucks-for-the-i7/
this is a nice read. It shows comparisong between the 6700HQ and 6300HQ (both quad cores)
IMO, go for the SSD. once you go SSD, you never go back.
or, you can buy the i7 one, and add your own SSD (if you can afford it)
https://linustechtips.com/topic/669645-laptop-choice-help/#findComment-8675107
