26 minutes ago, Mcjazz said:
Can you guys help me. I decided to make my own computer and I need help seeing if my parts are good or I need improvements I have a budget of around $1500 here's my build: http://pcpartpicker.com/list/97Fgnn
CPU: Intel Core i5-6600K 3.5GHz Quad-Core Processor  ($227.99 @ SuperBiiz)
CPU Cooler: Thermalright Macho Direct 73.6 CFM CPU Cooler  ($47.99 @ Amazon)
Motherboard: MSI Z170A GAMING M5 ATX LGA1151 Motherboard  ($152.98 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-2133 Memory  ($69.88 @ NCIX US)
Storage: SK hynix SL308 250GB 2.5" Solid State Drive  ($64.99 @ SuperBiiz)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive  ($48.48 @ NCIX US)
Video Card: MSI GeForce GTX 1070 8GB Video Card  ($449.94 @ NCIX US)
Case: NZXT Noctis 450 ATX Mid Tower Case  ($136.99 @ SuperBiiz)
Power Supply: EVGA SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($82.99 @ SuperBiiz)
Keyboard: Razer BlackWidow Chroma Wired Gaming Keyboard  ($134.99 @ Best Buy)
Total: $1417.22
Generated by PCPartPicker 2016-09-25 20:32 EDT-0400
Added SSD
Much better PSU
Much better (and silent) CPU cooler.
We have a NEW and GLORIOUSER-ER-ER PSU Tier List Now. (dammit @LukeSavenije stop coming up with new ones)
You can check out the old one that gave joy to so many across the land here
Computer having a hard time powering on? Troubleshoot it with this guide. (Currently looking for suggestions to update it into the context of <current year> and make it its own thread)
Computer Specs:
Mathresolvermajig: Intel Xeon E3 1240 (Sandy Bridge i7 equivalent)
Chillinmachine: Noctua NH-C14S
Framepainting-inator: EVGA GTX 1080 Ti SC2 Hybrid
Attachcorethingy: Gigabyte H61M-S2V-B3
Infoholdstick: Corsair 2x4GB DDR3 1333
Computerarmor: Silverstone RL06 "Lookalike"
Rememberdoogle: 1TB HDD + 120GB TR150 + 240 SSD Plus + 1TB MX500
AdditionalPylons: Phanteks AMP! 550W (based on Seasonic GX-550)
Letterpad: Rosewill Apollo 9100 (Cherry MX Red)
Buttonrodent: Razer Viper Mini + Huion H430P drawing Tablet
Auralnterface: Sennheiser HD 6xx
Liquidrectangles: LG 27UK850-W 4K HDR
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606305
Total: $1417.22
Added SSD
Much better PSU
Thank you for taking the time to reply
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606329
Just now, Mcjazz said:
Asus 1080p 60hz monitor
I would upgrade your monitor then. Would you rather have more detailed images or faster response and smoother gameplay?
Computer Specs:
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606354
He could always add a new 2560x1440 monitor at a later date.
Squeezed in an i7 for a bit more money.  Left mass storage out, it can be added in later... when it is needed.
CPU: Intel Core i7-6700K 4.0GHz Quad-Core Processor  ($328.99 @ SuperBiiz)
CPU Cooler: CRYORIG H5 Ultimate 76.0 CFM CPU Cooler  ($46.99 @ Newegg)
Motherboard: Gigabyte GA-Z170MX-Gaming 5 Micro ATX LGA1151 Motherboard  ($135.66 @ Newegg)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3000 Memory  ($74.89 @ OutletPC)
Storage: Crucial MX300 275GB 2.5" Solid State Drive  ($68.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX 1070 8GB FTW DT GAMING ACX 3.0 Video Card  ($429.99 @ B&H)
Case: Phanteks ECLIPSE P400 ATX Mid Tower Case  ($69.99 @ NCIX US)
Power Supply: SeaSonic G 550W 80+ Gold Certified Semi-Modular ATX Power Supply  ($73.99 @ Newegg)
Case Fan: NZXT Air Flow Series 83.6 CFM  140mm Fan  ($7.99 @ Directron)
Keyboard: Corsair STRAFE Wired Gaming Keyboard  ($99.99 @ Best Buy)
Total: $1345.46
Generated by PCPartPicker 2016-09-25 20:46 EDT-0400
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606369
4 minutes ago, Mcjazz said:
Both would be nice but if I had to pick one it would be response time
I will add a 144Hz monitor then. Would you mind downgrading the keyboard to one without RGB lighting?
Motherboard: Gigabyte GA-Z170X-Gaming 3 ATX LGA1151 Motherboard  ($139.88 @ OutletPC)
Storage: Plextor M7V 128GB M.2-2280 Solid State Drive  ($44.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($45.71 @ OutletPC)
Video Card: Gigabyte GeForce GTX 1070 8GB G1 Gaming Video Card  ($428.89 @ OutletPC)
Monitor: AOC G2460PQU 24.0" 144Hz Monitor  ($229.99 @ B&H)
Keyboard: Razer Blackwidow Tournament Edition Wired Gaming Keyboard  ($77.99 @ B&H)
Total: $1533.29
Generated by PCPartPicker 2016-09-25 20:51 EDT-0400
Computer Specs:
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606379
7 minutes ago, wrathoftheturkey said:
For 1080p 60Hz, a 1060 is more than enough, no need to fork over the extra cash.
I picked a 1070 because i was thinking of upgrading the monitor later on when they become a little more affordable but I see where your coming at
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606380
I think you can definitely get a monitor alongside a computer to drive it for your budget :) This option keeps the RGB keyboard.
CPU Cooler: RAIJINTEK THEMIS 65.7 CFM Sleeve Bearing CPU Cooler  ($24.99 @ Newegg)
Power Supply: SeaSonic 520W 80+ Bronze Certified Fully-Modular ATX Power Supply  ($64.49 @ SuperBiiz)
Total: $1481.79
Generated by PCPartPicker 2016-09-25 20:56 EDT-0400
Computer Specs:
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606392
Total: $1481.79
Thanks the RGB plays a crucial part ?
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606405
That mobo won't let you overclock you need a z170 version. I would add an ssd for the os and programs, go for the evga ftw card instead of the msi one and get an evga gq, gs, g1 or g2 instead of the nex
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606409
The P400 case also has an RGB toogle for the front bit :)
Computer Specs:
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606411
If you can squeeze the budget switch the Plextor SSD for this one
http://pcpartpicker.com/product/KXkwrH/crucial-mx300-275gb-m2-2280-solid-state-drive-ct275mx300ssd4
Computer Specs:
https://linustechtips.com/topic/666766-new-pc-build-need-help/#findComment-8606419
