Help install fans please :)
Go to solution Solved by spark12072001,
plug pump into cpu_fan and the hub in cpu_opt. plug all fans in the fan hub
Alright so heres my new setup that Im at a stalemate with:
Asus Z170 DELUXE motherboard
Intel Core I7-6700k (will be overclocked)
Kracken x61 water cooler
Phanteks Enthoo Primo White case
Corsair 32GB ram
M.2 512GB SSD 950 pro
Heres my issue:
So I dont know where to plug the fans and the fan controller that came with the case into.
Do I rig the the case fans to the fan controller and plug that into CPU-OPT and the kraken pump into CPU-Fan?
Also the radiator fans are 4-pin so do I plug those into the fan controller which has 3-pin or do I plug those into CHA_FAN1 and 2?
https://linustechtips.com/topic/664272-help-install-fans-please/
I5 4470     -     Cooler Master Hyper 212 evo    -    Asus Strix GTX960    -    12Gb ram    -    Adata SP600 128Gb    -    Seagate 2Tb    -    AsRock Fatal1ty B85 Killer    -    Seasonic M12II EVO 520
IN WIN 703    -     Dell P2414H    -    LG Flatron M197WDP    -    CMSTORM Quickfire XT with MX blue's    -    Logitech  G502
Quote
"To finish first, you first have to finish"
https://linustechtips.com/topic/664272-help-install-fans-please/#findComment-8580785
Yes
Quote
https://linustechtips.com/topic/664272-help-install-fans-please/#findComment-8586768
