This is my first Pc, I plan on only putting in 1 of those graphics cards in at first and add the second one later, my budget is $1,000 to start and i already have the case. What do you think? Is there parts I can use for cheaper and better? I am planning to do live streaming, play video games on it and produce video on it.
https://linustechtips.com/topic/651089-building-my-first-pc/
You could probably save some money on the CPU by picking an i5 instead, since you probably won't benefit much from hyper threading. Also, for video recording and streaming , you'll probably want a Nvidia GPU, as Nvidia GPU's can capture the frame buffer without affecting the FPS noticeably.
https://linustechtips.com/topic/651089-building-my-first-pc/#findComment-8366062
