16 minutes ago, Luminant said:
Does anyone know how to fix this? I have a graphics card but when i plug it in the computer doesnt start at all. Ive tried 3 graphics all the same thing ive replaced the ram and cleard the cmos doesnt do anything.
Untitledvideot_20160806_130119.mp4
Which CPU are you using.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239575
7 minutes ago, Luminant said:
Intel pentium 32020 on an msi H61m-P20 (G3)
8Gb's of mixed ram
Shaw Evo-775Max
That chip from what I can see does not have on-board graphics. You would need a dedicated graphics card.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239630
8Gb's of mixed ram
Shaw Evo-775Max
Here is the official spec sheet from Intel on your CPU.
http://ark.intel.com/products/37160/Intel-Pentium-Processor-T3200-1M-Cache-2_00-GHz-667-MHz-FSB-Socket-P
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239638
3 minutes ago, legacy99 said:
Intel Processor G2020 is the one i have i missed spelled it my bad.
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239654
http://ark.intel.com/products/71070/Intel-Pentium-Processor-G2020-3M-Cache-2_90-GHz
ok so that does have on-board. Do you have a dedicated card you can use to test to see if you get a post? When its on like that, if you press the power button, does the system shut down right away, or do you have to hold it in?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239659
Also, you can try taking  your RAM out and try each individually in each slot. I had a similar issue with my Z97 board where slot 1 was dead, and if I had a stick in there, I would get the same thing, just a solid black screen, no post.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239670
It has on board and i have a two desicated cards i can use  but when i plug them in its the same black sceen with no post. And i have to hold the power to trun it off.
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239676
so my guess then is the RAM. Try my above post with the RAM sticks.
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239680
ive tried that already and ive tried  my old set of ram still the same thing :(
I think its your motherboard honestly. Do you have another board you can test the CPU in?
Community Standards
"Beast Mode"
https://linustechtips.com/topic/638786-i-need-your-guys-help/#findComment-8239696
