PS4 doesn't recognize USB-Stick !?
6 hours ago, Marmaran_1 said:Hello guys,
I changed out the 500GB HDD of my PS4 out with a new 2TB one from Seagate. Amazon link
The problem is the PS4 doesn't recognize the USB-Stick with the update file.
(I formatted it to FAT32 and the file is in the right spot: PS4/UPDATE/PS4UPDATE.PUP)
Can you please help me I'm really frustrated right now.
(yes I saved my data before changing the hdd)
You probably have the Update file and not the full OS file.
How big is it? If you have one that's about 300MB, that's the wrong one. The full OS file is almost 900MB.
Download it from here:
https://www.playstation.com/en-au/get-help/ps4-system-software/
Scroll to the very bottom and expand the section titled, "Perform a new installation of the system software."
Download that one and try it again. It has step-by-step instructions, too. Make sure you read them to ensure you're not missing a step or otherwise doing something incorrectly.
