Mouse freeze for a second + audio "cracking"
SniphzR
So I have a Steelseries Sensei (and an asus xonar dx) but it shouldnt matter, because this problem came out recently. The mouse freezes for a second, then continues moving (Most of the time I have to restart the PC after half an hour, because a full freeze comes in, and the mouse wont move) + When this happens (not at all boot) the audio cracks every 5 seconds (I use VLC). When I restart the PC, its a random that if it will be good or bad. AGAIN: This whole thing started about a week ago. I had the same mouse and audio card before, and it was all good.
May the problem can be related to the mobo? or idk.
Asus Z170-A | Intel Core i7-6700K@4.6Ghz | Cooler Master 612s | ZOTAC GTX 980 AMP! Extreme 4GB | Kingston HyperX Savage 1x8Gb 3000MHz CL15 | Aerocool Mechatron White Edition (Steel Edition) | Corsair CX650M | Fostex HP-A3 | Windows 10 Professional 64Bit | Superlux E205U | Samsung 840 Pro 256Gb | Seagate Barracuda 500GB 7200Rpm | BENQ XL2411Z (1ms, 144hz, 24'', 3D) | HiFiMAN HE-400i | Logitech G910 Orion Spectrum | Logitech G703 Wireless | Razer Goliathus Control Large | T-Moblie 120/10 Mb/s | Steam profile
Sounds Like driver or connection issues
I would get a fresh install of VLC and get latest drivers for your mouse and sound card
Also look in device manger to see if any of the drivers have a yellow triangle next to them
If so uninstall the driver and reinstall the component
Also I would check to any physical damage to your mouse or sound card or speakers/headphones
IntelCorei54670k,Maximus VI Formula,Swift tech H220, 16gigs Corsair Dominator platinums, Asus DCUII GTX 780,1x256 840 evo, 1x 2TB Segate barracuda, Corsair AX 860,
3 X Noctua NF-F12, 2x Noctua NF A-14, Ducky Shine 3 Blue Leds Blue switches, Razer Death Adder 2012, Corsair vengence 1400
I found 2 with the yellow triangles.
Translation:
   - Other devices
         - Unknown device
         - PCI simple communications controller
I would go to the website for your motherboard and download and install all the drivers, even the ones already installed (just in case). Then I would install the sound card drivers. If you are still having problems, try running the system without the sound card and see how she works.
When in doubt, re-format.
Try removing your sound card and see if the triangles are still there
Is this with the up to date drivers
I would also update your motherboard drivers  just in case
