I Wanna purchase all my parts for this pc, but i dont wanna create multiple accounts and i want them cheap. Is there a website that has all these parts? And i have created this chart, tell me if its right http://au.pcpartpicker.com/user/Its_Joshua_S/saved/#view=3WdNnQ
To explain, if you wanted a CPU From IJK It would cost $480, and if you wanted memory from CPL It would cost $109.
Name
Unmart
IJK
Centre
CPL
MWave
Pccg
Ple
Scorptec
Storm
Ram
CPU
$479
$480
$481
$485
$495
$499
$499
$503
$519
CPU Cooler
$35
Mother
Board
Memory
$103
$105
$109
Storage
$205
$207
$215
$209
$215
$219
$219
$219
$239
$216
Video Card
$769
$769
$769
$769
$769
$779
$799
Case
$99
Power
Supply
$134
Operating
System
$137
$138
$159
$149
$149
$159
$165
Case Fan X2
$16
Extra Storage
$98
$98
$99
$99
$109
$103
$139
TOTAL!
(Not all Parts Are Included)
$1,590
$1,795.
$1,827.
$1,671.
$1,797.
$1,860.
$986.
$1,789
$897
$216.
X2 Means i have to buy two of that part.
And please tell me all the websites that have this motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813132586&nm_mc=KNC-GoogleAdwords-PC&cm_mmc=KNC-GoogleAdwords-PC-_-pla-_-Motherboards+-+Intel-_-N82E16813132586&gclid=CjwKEAjw-_e7BRDs97mdpJzXwh0SJABSdUH0K38NS99u1mFkdHjrOc_Dkl4xK4JWIkqn3hIqk16GPRoCwu7w_wcB&gclsrc=aw.ds
My PC Currently Is The P2-1320a.
https://linustechtips.com/topic/624350-purchasing-parts/
Name
Unmart
IJK
Centre
CPL
MWave
Pccg
Ple
Scorptec
Storm
Ram
CPU
$479
$480
$481
$485
$495
$499
$499
$503
$519
CPU Cooler
$35
Mother
Board
Memory
$103
$105
$109
Storage
$205
$207
$215
$209
$215
$219
$219
$219
$239
$216
Video Card
$769
$769
$769
$769
$769
$779
$799
Case
$99
Power
Supply
$134
Operating
System
$137
$138
$159
$149
$149
$159
$165
Case Fan X2
$16
Extra Storage
$98
$98
$99
$99
$109
$103
$139
TOTAL!
$1,590
$1,795.
$1,827.
$1,671.
$1,797.
$1,860.
$986.
$1,789
$897
$216.
I usually go for the one that sells are the stuff you need for cheapest, has good postage service and has stock for the stuff i need
''Daddy CumTits 2.0'' (pc):
CPU - Intel i7 8700k
GPU - Asus Strix 1080 8gb
RAM - 2x8gb Corsair Vengance
MOBO - Asus Prime Z370-p
PSU - Corsair RM750x
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058310
35 minutes ago, blxtn said:
How is your 8350? Perform well? Thinking about getting one...
Performs decent for the price, but if you want path to upgrade go with intel. And if you decide to get one of these its 970 chip for default and uc and 990 for oc. And unless your case has fan above mobo then its good idea to get cpu fan that blows straight into the mobo.
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058625
 Im on a major budget and I don't want to spend money on a new mobo and cpu.
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058631
what chipset do you have on your mobo atm?
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058638
ASRock 960GM-VGS3 FX
Its that mobo, not sure exactly about the chipset, but I do know its AM3+
It will run it, but not that great. Generally you need 8pin cpu connector in mobo to run 8 cores from amd, So if youll prob have to get new psu(unless yours have 8pin cpu connector allreadi) , mobo that has 970 atlest in the name and the 8350. if you only need the mobo and cpu you can prob get micro atx 970 board for cheap, but they need to have that 8pin connector.
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058692
Yes, I have an 8 pin cpu connector, but my MOBO only supports a 4 pin connector
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058738
It will most likely render your mobos vrm useless, since it will overheat it constantly. So youll need new mobo and the cpu itself and youll prob can use the stock cooler for while if you undeclock the cpu slightly (no need if it doesnt throttle), but it will still sound like jet engine, so you prob should get cpu cooler for it ( with the fan blowing down ). With this cost youll prob get like i5 and mobo for it (maybe).
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058766
so does that mean It wont run at max performance and wont run better than an fx 6300?
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058767
Ah ill just stay with my 6300, i dont see myself getting an i5 anytime soon lol
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058776
15 minutes ago, I Need A PC Build ASAP said:
Omergawd could we anwser my problem on my thread pls
Newegg, Amazon, ncix.....
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8058904
7 hours ago, I Need A PC Build ASAP said:
Would that evolve me signing up for multiple accounts?
No just pick one of them ofc and get all of them there
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8066923
But no website has all the parts i need in stock!
well its only 1 or 2 more acounts to make and it really isnt that slow. Why you againts multiple acounts anyway?
https://linustechtips.com/topic/624350-purchasing-parts/#findComment-8067395
