When you get a new mobo, make sure it has onboard usb 3.0 usb headers. Your case should have a cable with a blue tip leading from where the usb ports are. This is what you plug into the usb 3.0 headers. If you dont want to go over $300 budget then just hide the cable.
2 minutes ago, Mikeak172 said:
or you can look for a USB PCI-E card like this (if you have enought PCI-e lanes):
https://www.amazon.com/Mailiya%99-Superspeed-Express-Expansion-Connector/dp/B01G85LFEK/
Note this is for USB 3.0
yes but that doesnt solve the front panel issue.
