Problem with the Logitech g502
Solved by Ichi,
5 minutes ago, CALBIX said:Ok Thanks for the help, Ill try and sort it out as soon as possible!
Or if you want to do it the ghetto way, add some rubberized stuff that allows you to grip the mouse better at the sides.
I won't guarantee it will solve your problems though, do it at your own risk.
Currently I'm using a Deathadder 2013 and it have a good rubber grip on the sides so I don't need to grip it as much when using it and it won't slip.
Linus did a video about it way back.
