Can't configure fan speed
Chandres
So, I have been wanting to configure my fans. My z170xp sli lets me do that on BIOS, but doesn't let me pair it up to the GPU temps. So I tried out SpeedFan and this happened
I tried to configure stuff but it didn't detect any fans. While corsair link 4 found all system fans it didn't let me confirgure them.
Someone help?
(Also I watched JayTwoCents video it has nothing to do with my problem)
Someone help?
that shit never works, basically if you want top fan speed, plug to psu, somewhat regulated speed, motherboard, lower speed? use a downvolgintg adapter, or just get a cheap dial up fan speed controller, theres lots of them in amazon, if i recall no computer fan reacs to GPU temps, only motherboard/cpu temps
Main PC:| CPU: Ryzen 5 2600 @ 4.1, MOBO: Asus B350 PRIME , RAM: LPX Vengance 2400 16gb kit, GPU: 980Ti Poseidon Platinum 6gb
                PSU: SilverStone Strider Gold Evolution 1200w , CASE: HAF 932  HDDs:240gb EX900 HP NVME 6TB (2x3 Seagate Barracuda)
                COOLING: ThermalTake Contac Silent 12
Laptop:MSI GL62 7RD  CPU: Core i5 7300HQ, RAM: 16GB 2400mhz, :GPU GTX 1050 2GB: HDDs: 256gb adata NVME + 1TB HDD
love all brands, will go for whats cheaper for my needs
Ive seen lots of software which lets you create temperature graphs
SpeedFan normally lets you it's just not working for me
ive tried that crap, it has never worked for me, just never with any kind of computer, i basically gave up and got either a case with fan controller, or a bay fan controller
https://www.amazon.com/Kingwin-Channel-Multi-Fan-Controller-FPX-001/dp/B00DP9WRZY/ref=sr_1_5?s=electronics&ie=UTF8&qid=1467236094&sr=1-5&keywords=fan+controller
i just works, perfectly
