Hello guys
I am upgrading my CPU soon and i was considering the AMD FX 6300 as a good budgetish processor
I would like some suggestions on alternates and i will be changing my motherboard along with it.
My main requirement is games.
My Specs
Summary
        Operating System
            Windows 10 Pro 64-bit
        CPU
            Intel Core 2 Duo E4600 @ 2.40GHz
            Conroe 65nm Technology
        RAM
            4.00GB Single-Channel DDR3 (6-6-6-15)
        Motherboard
            Gigabyte Technology Co. Ltd. G41M-Combo (Socket 775)
        Graphics
            Panasonic-TV (1366x768@60Hz)
            2047MB NVIDIA GeForce GT 630 (NVIDIA)
Thanks.
https://linustechtips.com/topic/606554-suggestions-for-my-cpu-build/
5 minutes ago, Mr. Tsao said:
If you're looking for games I would go with a lower-ish end i5 because it had better performance-per- core than AMD, and games don't require the extra 2 cores that AMD offers over intel
The i5's are kind of out of budget, plus an overclocked fx 6300 can somewhat outperform an i5 stock, but I see your point.
