Hi,
I have Sony Xperia Z3,  I want to install Android N Developer Preview on my phone, but that will erase all my apps and data. I know I can backup and restore perfectly using custom recovery but installing custom recovery will require to unlock my bootloader. I'm ready to unlock bootloader but after I unlock bootloader I will not be able to flash or install official software from Sony. Will relocking the bootloader allow me to install the official software from Xperia Companion?
https://linustechtips.com/topic/603017-bootloader-unlock-and-lock/
3 minutes ago, Sauron said:
Unlocking the boot loader will wipe your data for security reasons. You'll need to find a different solution.
Ya, but after I reclock can I install software from sony? Or should I flash it externally (ftf files)?
In theory a relocked phone is indistinguishable from one that has never been unlocked. If however you installed a different rom, nothing guarantees any of the software will work on it. If you put the stock rom back it should work like new.
What I meant is that your data will be wiped BEFORE you get the chance to install a recovery program, because the device wipes itself if the bootloader is unlocked.
sudo chmod -R 000 /*
relocking your bootloader will also wipe your entire phone. includes user data as well. so when you say flash externally you mean with fastboot?
