Capture Card Audio
Go to solution Solved by Alec10121,
15 hours ago, Scruffy90 said:
I went through the same issue a few months back.
I found out how to get it going this morning. I set my Realtek Audio to default, sent that to the capture card through stereo mix. Then I was able to use virtual audio cable to duplicate that for my headset. I than set my mic to listen through skype, now it works fine. Thanks for the help that you were able to provide :)
I bought an Elgato HD60 for streaming and came home to set it up. Everything works fine except for one thing. I am using a dual pc streaming set-up and unfortunately, a usb headset(Logitech G35). The issue arose when I tried to listen to all my pc audio and stream it. The audio can only be used with one or the other. I cannot split it physically because of the fact that it is a usb headset and I could not find a virtual splitter that worked for me. Please help it would be much appreciated.
https://linustechtips.com/topic/582483-capture-card-audio/
There is a way to loop the audio and reroute it through an output using audacity. Unfortunately I dont remember what the feature is called.
Windows 10 Edu | Asus ROG Strix X570-F Gaming | Ryzen 9 3950x | 4x 16GB G.Skill Trident Z RGB| ROG Strix GeForce® RTX 2080 SUPER™ Advanced edition | Samsung 980 PRO 500GB + Samsung 970 Evo Plus 2TB + 8TB Seagate Barracuda | EVGA Supernova 650 G2 | Alienware AW3418DW + LG 34uc87c + Dell u3419w | Asus Zephyrus G14
https://linustechtips.com/topic/582483-capture-card-audio/#findComment-7603735
I'll take a look I haven't seen anything about it and that's a surprise because I've been working at this for 3 hours... xD
https://linustechtips.com/topic/582483-capture-card-audio/#findComment-7603742
I went through the same issue a few months back. I couldnt get it to work properly in my set up. In the end I said screw it and bought an XLR mic and an audio recorder with interface. I believe the feature is called WASAPI Loopback in audacity. Might be the closest thing I could think of.
https://linustechtips.com/topic/582483-capture-card-audio/#findComment-7603751
https://linustechtips.com/topic/582483-capture-card-audio/#findComment-7606062
