Wifi card help
Go to solution Solved by swordsman247,
Not sure, reboot and try to  reinstall?
I just installed the gigabyte GC-WB867D-I Rev. 4.2 2x2 802.11ac and Bluetooth 4.2
i installed the drivers but Windows won't detect the card and won't let me connect to wifi
this wifi card is brand new
could it be dead?
please help any help is greatly appreciated
i can also post pictures if necessary
https://linustechtips.com/topic/569349-wifi-card-help/
10 minutes ago, swordsman247 said:
okay you need to remove the device from the manager. Right click and select uninstall and delete saved drivers. then rerun the install package.
I uninstalled it from device manager and checked the box for delete saved drivers and I got this error
https://linustechtips.com/topic/569349-wifi-card-help/#findComment-7472396
