i just got a new PSU for my computer to hopefully power my new graphics card. so i took out my old one, and put in my new power supply, and i found out that my system refused outright to turn on. when that happened, i took it out and put my old PSU, and it worked, so that told me 2 things, that I was plugging in all of the correct cables, and none of my hardware was dead. so all that happens when i turn on my power supply is that it gives off a short burst of power, and turns off. is the PSU  defective, or is there another thing that I am missing?
Maybe it's a bad batch? did you plug everything in properly? did you flick the power switch on?
Hope this helps :P
CPU: Ryzen 5 5600x 4.9Ghz PBO    SSDs: 250GB 850 Pro           STEAM: KezzaMcFezza
GPU: GTX 1070 Strix                                     250GB 970 Pro           MOBO: MSI MPG B550 Gaming Plus
HDD: 1TB WD Black Drive                             500GB 860 Evo          MOUSE: Logitech G502
Hope this helps :P
thanks, it may have also been damaged during shipping because the box was really beat up, but yes, i did plug in all of the connectors, i selected the right voltage, and i turned on the power switch, and nothing... thanks anyways!
Yea that happened to me, the PSU was damaged in shipping but it still works! just with a bent chassis xD
Hope this helps :P
well, thanks for the help. Im not too disappointed thought, a new one will only set me back another 46 dollars, if anything at all, so nothing too terrible XD.
Or send it back and get another one for nothing!
