So running cat5e cables turned out to be a real pain and I was thinking about just using my electrical system to run my connection through except I don't know anything about the technology other than that it is a wired connection via the electrical system. So... what model should I get that won't throttle my connection speeds?
https://linustechtips.com/topic/564138-power-line-adapter/
I've used this kit before and they work great!
http://www.amazon.com/gp/aw/d/B00S6DBGJM/ref=s9_top_hm_awbw_b50jE_g147_i8?pf_rd_m=ATVPDKIKX0DER&pf_rd_s=mobile-hybrid-11&pf_rd_r=1099P82H1RCVK1F34V2A&pf_rd_t=30901&pf_rd_p=3b52e653-8edc-59d8-8d3e-b10a96ef91ed&pf_rd_i=1194444
You literally just plug em into an outlet and you're good to go :)
If you want more info on Powerline adapters check out this video:
Want to build yourself a NAS? Check here!
https://linustechtips.com/topic/564138-power-line-adapter/#findComment-7422447
