hey guys so i just got a new ssd samsung 840 evo and installed windows 7 no prob and i noticed on the program that comes with it. its telling me about some ahci mode is not on and it cant detect some sata interface?  now i looked in my bios and i saw what its talking about i think but when i enable it my ssd crashes so im just wondering what might be going on?
pc specs are
MB - Gigabyte G1 Sniper X58 first gen
CPU - intel i7 960
Ram - Corsair Vengence 6 Gigs
PS - Corsair hx1000
GPU - His 6870
https://linustechtips.com/topic/56084-help-setting-up-840-evo/
The problem here is that you installed windows on IDE mode (happens all the time, I did the same thing with my first SSD :P)
You need to change the windows registry to AHCI and then after that change the BIOS settings to AHCI.
OCZ has a nice guide you can follow to do this:
http://www.ocztechnologyforum.com/forum/showthread.php?69682-Change-from-IDE-to-AHCI-after-Installation
Respect the Code of Conduct!
>> Feel free to join the unofficial LTT teamspeak 3 server TS3.schnitzel.team <<
>>LTT 10TB+ Topic<< | >>FlexRAID Tutorial<<>>LTT Speed wave<< | >>LTT Communies and Servers<<
https://linustechtips.com/topic/56084-help-setting-up-840-evo/#findComment-767755
thnx i just ended up doing a fresh install after turning the mode thnx for the info though
https://linustechtips.com/topic/56084-help-setting-up-840-evo/#findComment-771776
Cool, sorry for missing this topic when you posted it, would have saved you some time :(
https://linustechtips.com/topic/56084-help-setting-up-840-evo/#findComment-771803
