Hello everyone, so basically, my :Z drive keeps appearing and reappearing at random, it died down for a couple days but then it started doing so again.  It doesn't really seem to have a pattern, and it(usually) gets fixed by rebooting.
Specs:
Asus Z170 Maximus z170 Hero
Intel Core i5 6600k
EVGA gtx 970
EVGA 850 B2 PSU
(C: Drive) Samsung 850 EVO 500 GB
(Z: Drive) WD Red 2 TB Drive
Ive checked the SATA Connections, both drives are running from one sata power, so I dont know if that could be a problem.
Python/C# Programming
Code to learn, don't learn to code. -Napalm
https://linustechtips.com/topic/558486-hard-drive-randomly-disconnects/
try changing the sata cable since it could be a broken connector or simular
Main build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD4  RAM: corsair ballistix 2400mhz 4x4gb  GPU: Asus GTX 970  PSU: corsair rm1000  SSD 1: Samsung 840evo 500gb  SSD 2: Samsung 850evo 500gb  HDD: Western Digital red 3tb  Case: Phanteks Enthoo pro M  CPU cooler: corsair h80i
Second build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD5 WIFI  RAM: G.skill 2666mhz 4x4gb  GPU: Nvidia GTS 450 (soon to be upgraded)  PSU: corsair HX650  SSD: Samsung 850evo 250gb  Case: Cooler Master 430 elite  CPU cooler: Cooler Master hyper 212 evo
Third build
CPU: xeon x5690  MotherBoard: Evga x58 classified 4way-sli  Ram: Patriot 1600mhz 4x3gb  GPU: Asus HD6970  PSU: fractal newton r2 1000w  SSD: crucial m500 240gb  Case: Cooler Master Haf X  CPU cooler: Mega Shadow
19 hours ago, matwoodson said:
Sata data or sata power?
try the data first then if that doens't work then try another sata slot in the motherboard and if that doens't work then power
Main build
Second build
Third build
