I want to do some good overclocking of my intel i5 4690k amd I would like to know If anyone one can suggest a water cooling setup as close to $50 as possible
I have an Anet A8 as my project printer and a i3 MK3 for when I want things to work.
I extrude my own filament and haven't saved a penny yet.
My PC:
CPU: Intel i7 8700k
Motherboard: MSI Z370-A Pro
RAM: G.Skill Ripjaws V (2x8GB) DDR4-3200
GPU: GTX 1070 Founders Edition (OC'd)
Storage: 2x 2TB Seagate 5400RPM, 128GB ADATA SSD
Power Supply: EVGA Supernova 750w  B2
Cooling: Noctua NH-D15. 3 Intake Fans, 2 Outtake
Case: Fractal Design Define R6
https://linustechtips.com/topic/558450-cheap-water-cooled-cpu-setup/
Just now, Nacho Marco Segui said:
An air cooler would be better at this price point, or you can always go the Aliexpress route and make a custom loop for less than 50 rupees( Not recommended though)
I looked around and found a setup for water cooling for around $75 would it be better to just get a good fan for that price?
My PC:
CPU: Intel i7 8700k
3 minutes ago, Nacho Marco Segui said:
Could you tell us which model it is or a link?
Corsair H75
My PC:
CPU: Intel i7 8700k
If you have enough clearance in your case, i would go for a high end air cooler, it will perform better than the H75
Ok any suggestions?
My PC:
CPU: Intel i7 8700k
5 minutes ago, VoyexTech said:
Ok any suggestions?
http://pcpartpicker.com/part/phanteks-cpu-cooler-phtc14pebk for 75, really nice cooler
http://pcpartpicker.com/part/noctua-cpu-cooler-nhd15 Over budget, but great quality
http://pcpartpicker.com/part/be-quiet-cpu-cooler-bk018 If you care about looks, although the phanteks also looks good and it is cheaper
