What resolution are you playing on? What are the rest of your computer specs ? Which games exactly and at what settings? Are you using the latest drivers, and what other software is running in the background?
There are many factors that could be causing this my friend, you need to be more descriptive...
7800x3d - RTX 4090 FE - 64GB-6000C30 - 2x2TB 990 Pro - 4K 144HZ
PCPP: https://uk.pcpartpicker.com/list/mdRcqR
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342509
kind of an idiot question, you sure you got the right drivers? if you do try reinstalling anyways, also it might be wierd if you're playing in window mode if you do
Main build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD4  RAM: corsair ballistix 2400mhz 4x4gb  GPU: Asus GTX 970  PSU: corsair rm1000  SSD 1: Samsung 840evo 500gb  SSD 2: Samsung 850evo 500gb  HDD: Western Digital red 3tb  Case: Phanteks Enthoo pro M  CPU cooler: corsair h80i
Second build
CPU: i7 5820k  MotherBoard: Gigabyte x99 UD5 WIFI  RAM: G.skill 2666mhz 4x4gb  GPU: Nvidia GTS 450 (soon to be upgraded)  PSU: corsair HX650  SSD: Samsung 850evo 250gb  Case: Cooler Master 430 elite  CPU cooler: Cooler Master hyper 212 evo
Third build
CPU: xeon x5690  MotherBoard: Evga x58 classified 4way-sli  Ram: Patriot 1600mhz 4x3gb  GPU: Asus HD6970  PSU: fractal newton r2 1000w  SSD: crucial m500 240gb  Case: Cooler Master Haf X  CPU cooler: Mega Shadow
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342517
7 minutes ago, Spyker9 said:
I play in 1920x1080 and i have a 5820k processor 16GB ram and a 1000 watt power supply I'm new to gaming pcs I got tired of consoles so decided to build my own pc and tried to go all out on it as much as I could
Then you should know a 1000Watt psu is useless for your configuration next time.
Running a intel core I5 oc 4,5Ghz , 16Gb , GTX980Ti oc 1450/1900 on a... 550Watt psu and i still have like 100+ Watt safe margin.
As a 980Ti owner like you , you should know a 980Ti won't protect you for usage like supersampling.
If you are running games in 1080P but with DSR or SSAA X4 , it's the equivalent of playing at 4K and a 980Ti won't like it at all.
I wish i could oc my body, during winter overheating would be great.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342576
There is still no use for a 1K W for 2 cards and SLI brings more stutter issue than anything else.
By the time you want to add another 980Ti you will have more efficient card on the market.
For exemple i was playng the last tomb raider in 2560*1080 ( 21:9 Aspect Ration)
With FXAA game run at like 80-90+ fps , once you start using SSAA , X2 drop it a 40+ fps , X4 drop at 25-30 fps.
Just stay away from supersampling and you will be fine with your 980Ti it's already otherkill for Full HD résolution.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342606
the 1000w psu is probobly becuase reasons. i use an rm1000 for a 5820k and a 970 and i'm not regretting my purchase, altough i got it for half the price and it had only been tested and then put back into a box
Main build
Second build
Third build
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342622
Check first your temperature and your settings.
Good thing to know for exemple if if your card reachs too high temps it will reduce frequency (so performance) by itself to reduce temperature.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342662
If you got it for half price sure but in the other case it's just money waste.
because you can spend your money on another aspect of your PC such as more efficient cooling or bigger SSD/
he has a 980ti and an x99 so i don't think the "spend your money on another aspect of your pc" argument works here c: it's about as good as he gets without spending way to much money
Main build
Second build
Third build
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342668
You can have a x99 and still improve your pc performance with :
better cooling ( more efficient / silent)
better or bigger SSD,
Better case ,
better cooler,
better monitor.
This is all about optimisation , spend 1$ here is one dollar not spend there.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342684
Just now, Spyker9 said:
My gpu sits around 40 to 50 degrees c
Then check your game setting something must be wrong in those.
And note if you are using Vsync with a 60Hz monitor , you won't get more than 60 fps for exemple.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342700
if he's using vsync it's wierd that the gpu is at 98% load since it "throttles" the gpu so it gets exactly that fps (this is why there's a small dip to 58-59 since it has to lower the usage and the game may need more in that exact moment)
Main build
Second build
Third build
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342710
And this is why the goal is to try things one by one since the user is new to pc gaming, Vsync was just a note since it's comon mistake from a ton of people to ask why they have only 60 fps when wome people claim having 100+.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342753
1 minute ago, Spyker9 said:
Ya I made sure vsync is off and I mainly use the GeForce experience optimal game settings
You should do the settings by yourself , GFE can be tricky and wrong about games settings.
Best option is a t least to try manual setting by yourself and to check what your performance are step by step and when it starts to get bad.
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342762
When you're at the high end, SLI makes sense. I would argue that in some ways the 980TI should be the only card someone should be using in SLI currently. While it's true some games have stutter issues with SLI, most don't. With all that said, more than 1 980TI isn't really needed for 1080p. OP should be looking at 1440p.
55 minutes ago, Spyker9 said:
I have a 980ti from zotac that I am receiving very little performance from and in every game I play over wolf says I am using 98% of the gpu is that normal? Any help would be appreciated
Can you run a benchmark? Try running 3DMark's Firestrike and let us know what you score (post the link).
CPU: AMD 5950X    MB: Asus ROG Crosshair VIII Dark Hero    RAM: HyperX Predator 64GB    GPU: Nvidia RTX 3090 Ti FE    SSD: Seagate FireCuda 530 2TB
PSU: EVGA 1200w P2    COOLING: EK AIO Elite 360    CASE: Fractal Design Torrent
   DISPLAY: LG CX48 4k OLED    AUDIO: HIFIMAN Arya SE
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342806
I ran the heaven benchmark and. It was around 2650 if I remember correctly on high settings I'm actually at work so don't have access to my desktop right now
https://chrome.google.com/webstore/detail/chrome-remote-desktop/gbchcmhmhahfdphkhkmpfmihenigjmpp?hl=en
Get that for the future :)
https://linustechtips.com/topic/557773-zotac-980-ti-problems/#findComment-7342929
