Issue with HDD or MB?
Solved by unidentical,
9 minutes ago, Oghorcath said:can shrink but cant extend volume.
Well I just learned something new. Apparently how the volumes are graphically located means something and windows can only extend a partition to the right. Since your ç: volume is already to the right it cannot be extended.
The only option I'm aware of beyond starting over would be to format the unallocated space as a new piston and use it as a second drive.
