Hello LTT-Forum,
I've recently bought a CM Force 500, and I don't seem to be able to mount 2x 120mm on the left side like they advertise unless I got a radiator of some sort, they did include 8x "rad screws" for the fans, but they're used in the front, anyone else with the same case in here that can help me or what can I do?
Thanks in advance.
https://linustechtips.com/topic/547002-cm-force-500-fan-issue/
Drill your own?
CPU - i7-4790k | CPU Cooler - NZXT Kraken X53 | Motherboard -  Asus Gyphon Z97 Armour Edition | RAM - Corsair Vengeance (2x8GB) 2400Mhz | Graphics Card - MSI GTX 1070 | Power Supply - Corsair CS750M | Storage - Seagate 1TB HDD | Samsung 500GB 850 Evo | Case - Fractal Design ARC Mini R2 | Colour Theme - Generic Red & Black
Operating System - Windows 10 Pro | Peripherals - Corsair RGB Mechanical K70 Keyboard/Corsair M65 Mouse
Click here to give a damn
https://linustechtips.com/topic/547002-cm-force-500-fan-issue/#findComment-7230152
Just now, Sidders91 said:
Wouldn't that void a warranty?
Possibly. If your warranty is already passed, you can hardly break the case by drilling a small hole for a screw to go through. But again, do it at your own risk.
https://linustechtips.com/topic/547002-cm-force-500-fan-issue/#findComment-7230221
9 hours ago, Sidders91 said:
Hello LTT-Forum,
Thanks in advance.
Use washers
https://linustechtips.com/topic/547002-cm-force-500-fan-issue/#findComment-7233364
