OK guys can you help me out with this one? I'm gonna build a new X99 platform system and some things are of most importance.
Just two requirements!
1. AS LITTLE DUST AS POSSIBLE
2. AS LITTLE NOISE AS POSSIBLE
The tricky part :
*Windowed case is a must
*AIO CPU cooler is a must
NOTICE: I don't require an absolute dustless and noiseless system just as little as possible.
In case you're interested in my potential future X99 build :
Intel i7 5820K
Asus X99-PRO
Corsair Vengeance LPX 3200MHz 4x4GB
Evga Supernova G2 750W
GPU = Possibly Pascal one
AIO = quiet and good looking one (Swiftech, Corsair or Deepcool)
Phanteks Evolv ATX
Cosmic Council Department of Defense ; Interplanetary Class 3 Relations & Diplomatic Affairs - OFFICE 117
https://linustechtips.com/topic/545008-noise-minimum-dust-minimum-x99-system/
The tricky part :
Hidden Content
get an rm1000 or rm1000i (fanless mode for wattages like yours)
get a STRIX graphics card, as they have a fanless mode when not gaming.  900 series also have a fanless mode you can enable, but i trust asus for stuff like this more
nepton 240m is basically the quietest aio, and the fans arent bad, but id still do noctua fans
a quiet edition case with a window does not exist
if you want a window more, find something like an h440
silence more, im gonna say the s340 (cause i think its pretty)
for dustless, put filters all over the fans and make must of them intakes.  boom
anything else?
I have nothing against FD R5 but Evolv ATX is more appealing to me. I don't like Cooler Master AIO, maybe to get something else and put Corsair SP fans on it? And for PSU you're thinking on RMi Series? I could go with RM750i then if it's any good vs Evga Supernova G2 750W....
I know that windowed case will leak noise but I'm not going to have a fully closed bigg-*ss can on my table, I like a little bit of eye candy ;)
Corsair fans are not the best in terms of noise, and AIO coolers can get noisy, remember they have a pump.A big air cooler will perform equally while being more silent
Ok, maybe some Noctua or Phanteks ones ? I know that high-end air cooler would probably be a more quiet solution but I'm aiming for clean look and less dust, it does not have to be noiseless, it can't be, just as little noise as possible.
