could you do that? Probably.
Without an OS? Definitely no.
Edit: You will still need something like pfSense as an OS
CPU: Ryzen 3700X VGA: RX 5700 8G RAM: 32GB 3200MT/s DDR4 Motherboard: B450 Aorus Pro
Storage: 2x1TB Crucial P2, 1TB Crucial MX500, 36TB NAS Cooling: Custom Loop 360mm & 280mm
PSU: Super Flower Golden Green HX 650W Case: Phanteks Enthoo Luxe
1 hour ago, Sunshine1868 said:
Even with an OS like pfSense, it would not be worth it. Switches have ASICs that would be much more capable than the hardware in a pc.
Totally agree.
Whilst pfSense is designed for network use, it's specifically designed for 'router' use. If you need a switch, a cheap used ProCurve would do the job much better.
