Watercooling with a reference gpu block
Go to solution Solved by FilipSebik,
Universal EK block
Hey guys,
I have a non reference PCB gtx 780 ti, the palit jetstream model, with a non reference pcb
I want to water cool it but unfortunately I cannot source the ekwb jetstream waterblock. I was wondering if it was possible to do some modding with blocks of copper or something to make it fit, or if there is something stopping this from being possible, seeing as there are lots of the normal 780 ti blocks on the market.
If you can find even technical specifications or tell me where to look it would be super helpful, I don't even know where to start looking.
Thanks,
https://linustechtips.com/topic/535909-watercooling-with-a-reference-gpu-block/
