Haven't really had any issue myself with my K70...
But try installing new driver here for it and see if that help's: http://www.corsair.com/en-au/support/downloads
If that doesn't help either re-plug the two USB connectors into new ports (3.0 just to be sure) or end up ramming it (if it's under warranty).
Just thought I'd add a side note, both those games are console port's and are poorly optimized for the PC!
Might add this later...
https://linustechtips.com/topic/535599-corsair-k70-ghosting/#findComment-7105007
