You need to buy a cooler for that CPU.
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/524642-my-first-pc-build/#findComment-6964183
yeah. looks pretty good, but is 32 Gb ram necessairy?
Cpu Cooler for silence, noctua D14
Yeah, 32GB just for my personal hobby :D and i still considering about noctua D14 and noctua nh-D15 as Howhurl recomend down there.
Yup, i do :wacko:
I guess but what is your budget and what resolution will you play at?
My budget is around $2500-$3000 and it's for gaming, graphic, movies and entertainment stuff :rolleyes:
ditch that full tower, you really don't need that. Go with a define S or R5, and get a noctua nh-d15 for your cpu
With the case, what do you think about NZXT H440 and define S? Which one more silent? :wacko:
https://linustechtips.com/topic/524642-my-first-pc-build/#findComment-6967787
Yup, i do :wacko:
is your hobby waching 20 tabs of porn simultaniously? because that wouldn't even need that much
to game or not to game, that`s the question
https://linustechtips.com/topic/524642-my-first-pc-build/#findComment-6970744
lol, idk how to say but i have some weird hobbies, and this is an example about that lol. It's just like when i open the system and see that have 32GB in there then i'm happy :D
https://linustechtips.com/topic/524642-my-first-pc-build/#findComment-6970782
yeah, and i'm still considering about NZXT H440 and define S. What'll you say?
depends on what you like about the looks and what you want to put in it, for watercooling I would definately get a Define S, if you like the looks of the H440.
You should get that one, depends on your preferences
https://linustechtips.com/topic/524642-my-first-pc-build/#findComment-6970949
