Hello, guys. I currently have an issue with my laptop that is quite impossible to ignore. I cannot do any task for a long period of time (10-15 mins of web browsing) and it shuts down after 5-10 secs after opening any game, e.g. DotA 2, CS:GO.
I'm suspecting it is an overheating issue so I went ahead and opened the laptop and replaced the thermal paste on the GPU & CPU with new ones and noticed that there is a bend on the copper of my heatsink.
(Image found online and the red circle represents the area with the bend)
post-268232-0-37554100-1450848502_thumb.
Could this be the problem or is there any other problems that I should be aware of?
https://linustechtips.com/topic/511006-hp-elitebook-8560w-issues/
The heatsink is supposed to be bent slightly. Have you ran a hardware monitor to see the temps?
Here are the temps. And I think the copper is bent more than "slightly", I think. I'll take a photo tomorrow.
Temps while browsing this forum. (And Steam is open)
post-268232-0-36371300-1450850915_thumb.
(I know it's ridiculously bad for idle temps but I've replaced the thermal paste and all, should I just replace the heatsink itself?)
