Help chosing a projector
Go to solution Solved by target39,
Its so cheap I'm afraid its just gonna die on me :P
But it's got the highest lamp life out of these three... It's also gotten wonderful reviews by users and experts.
Also, it's the only one of these three that may be overclockable to 100+hz.
Take a look at this:http://www.projectorcentral.com/parts_compare.cfm?add=7423&add=7476&add=6410
Requirements
3-D
1080p
be ceiling mounted
have 3000L+ brightness
$1400 but cheaper is better
I'm currently thinking about this
http://www.amazon.com/BenQ-SH910-4000L-Cinema-Projector/dp/B005AS3072/ref=pd_sim_sbs_op_1
<p>Wires Suck :angry:
!fY0|_|(4|\|R34[)7#!5PMM37#3(0[)3:1337 70833|\|73R3[)!|\|49!\/34\|/4Y 4|\|[)93741!f3
https://linustechtips.com/topic/50251-help-chosing-a-projector/
Have you checked out the Optoma HD25-LV?
It sells for $1188 with free in ear headphones and a 4GB flashdrive at BuyDig, which is a pretty reliable store in my opinion since I bought a 58" 3DTV from them nearly 3 years ago during holiday season and it arrived within 5 days with no problems whatsoever.
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670257
a 12 year old with a $1400 budget for a projector?
yep...i'm poor
Big Bertha3570k @ 4.5GhzASRock Fatal1ty Z777970 DCUII TOP EVGA GTX 780Swiftech H220 w/ NF-F1216GB RAM128GB Kingston HyperX 3K1TB Western Digital Black40GB Western Digital Raptor 10K PeripheralsMionix 3200 MouseCMStorm Quickfire Rapid w/ Cherry MX Blues2 x Dell U2713HM AudioAsus ROG Orion Pro HeadsetSony XB-500AKG K240Bose AE2i​Fiio E10
Samsung Galaxy S45.0" 1920x1080p Super AMOLED screen16GB Storage2600 mAh battery1.9Ghz quad-core Krait CPU2GB RAMCyanogenMod CameraNikon D310018x55mm NIKKOR VR Lens14.2 MP
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670279
Optoma HD25 or BenQ W1080ST. The BenQ is a short throw projector so at short distances you get bigger images than normal, which could be ideal if you're in an apartment or something small. You could even go $100 cheaper and get the BenQ W1070 which is almost identical to the W1080 model except that it's not short throw.
CPU: AMD FX 8350 OC 4.8GHz Cooler: Cooler Master Seidon 240M Mobo: ASUS Crosshair V Formula Z GPU: Radeon HD 7970 RAM: G.Skill Ripjaws X 16GB 1866mhz Red PSU: XFX 750watt Black Edition Storage: Samsung 840 Pro 128GB, 2TB WD Caviar Black, 2x1TB Samsung Spin Disk Case: Fractal Design Define R4 Black
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670292
yep...i'm poor
lol
my parents want a home theater and they suck with tech so its up to me
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670294
How about the Viewsonic PJD7820HD? It meets all your current requirements at half price ($699.99).
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670306
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670323
lol nice and can you find a ceiling mount for this
https://linustechtips.com/topic/50251-help-chosing-a-projector/#findComment-670340
