Hello! This is my first build, and I was hoping you all (the experienced ones) could offer some helpful advice! Any advice or tweaks to my system will be greatly appreciated. BTW this build is centered around gaming and future proofing (hopefully at least xD) Also on those compatibility notes i got, those are a major issue right (i don't NEED usb 3.0)?
http://pcpartpicker.com/p/w3wvXL
DEAD POST
https://linustechtips.com/topic/497167-my-1000-first-build/
get OS through the software exchange on reddit and get a corsair H60
Different PCPartPickers for different countries:
UK-----Italy----Canada-----Spain-----Germany-----Austrailia-----New Zealand-----'Murica-----France-----India
10 minutes ago, Stardar1 said:
Well, with an i7, GTX 1080, Full tower and flashy lights, it can obviously only be for one thing:
Solitaire.
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646607
http://pcpartpicker.com/p/s3mZNG
would go with this instead as this is more balanced and will let you take full advantage of your system
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646634
What about this? A more powerful CPU, 16 gigs of RAM and an SSD - the advantages over what you chose
CPU: Intel Xeon E3-1231 V3 3.4GHz Quad-Core Processor  ($242.99 @ SuperBiiz)
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($19.99 @ Newegg)
Motherboard: ASRock Fatal1ty H97 Killer ATX LGA1150 Motherboard  ($95.98 @ Newegg)
Memory: G.Skill Ares Series 16GB (2 x 8GB) DDR3-1600 Memory  ($59.99 @ Newegg)
Storage: OCZ Trion 100 120GB 2.5" Solid State Drive  ($34.99 @ Amazon)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($49.98 @ OutletPC)
Video Card: MSI Radeon R9 390X 8GB Video Card  ($409.98 @ SuperBiiz)
Case: Thermaltake Commander MS-I Epic Edition (Black/Red) ATX Mid Tower Case  ($34.99 @ Micro Center)
Power Supply: EVGA 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($75.39 @ Amazon)
Total: $1024.28
Generated by PCPartPicker 2015-12-01 19:49 EST-0500
CPU: AMD Ryzen 7 5800X3D GPU: AMD Radeon RX 6900 XT 16GB GDDR6 Motherboard: MSI PRESTIGE X570 CREATION
AIO: Corsair H150i Pro RAM: Corsair Dominator Platinum RGB 32GB 3600MHz DDR4 Case: Lian Li PC-O11 Dynamic PSU: Corsair RM850x White
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646639
Total: $1024.28
A xeon?
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646664
A xeon?
Yep, that particular Xeon is basically exactly the same in performance as an i7-4770 but it doesn't have integrated graphics, which are useless to you anyway.
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646673
Total: $1024.28
beat me too it
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646691
What do you mean by full advantage, and wouldn't the HAF case have better cooling?
ssd and a good cpu cooler are better also yes and no the haf doesnt really look great and the NZXT case has pretty good airflow so i think its better thats all
https://linustechtips.com/topic/497167-my-1000-first-build/#findComment-6646867
