fiio e10k for iPod?
By
XOpalmtrees
in Audio
in Audio
Solved by Guest Kloaked,
Its the iPod classic 7th generation 160gb
The headphones I'm using are Sennheiser HD 555
That iPod should be fine on producing proper audio unless you're into the whole audiophile movement who swear on dedicated .flac players or whatever.
I'd look into some better headphones and see what that yields for your ears.
RipperDoc5456 ·
Posted in Troubleshooting2 -
Nebcs ·
1
FancyPants101 ·
l3eyond ·
1
