Fedora Installation Help
Solved by vanished,
I've been using the USB's drive, which is D. Have a suggestion as to what else I should use?
It's not D unless you are booted into Windows and it assigns it to D. That is a completely arbitrary file naming structure that is windows-specific and doesn't apply in the BIOS
My suggestion is to find how the BIOS refers to different devices and use that
