I want to make a new build and I want to do water-cooling for the CPU and GPU on this one, this is my 1st time doing water-cooling since this is an expensive build i want to go whit  good water-cooling equipment looking to spent around $200-$400 USD   but try to keep low, not like if it was for a show  just high quality, good protection,easy maintenance,good looks and red tubes not red color liquid since i have not herd good things about that. I have spent days trying to figure out how this works but, I do not want to buy things and they are not compatible. the pc parts are below. by the way, any tips would be great.
PCPartPicker part list: http://pcpartpicker.com/p/s66RdC
Case: InWin 909
GPU: EVGA GeForce GTX 980 Ti /w Waterblock
CPU: *Intel Core i7-6700K 4.0GHz Quad-Core Processor
Motherboard: Asus MAXIMUS VIII EXTREME EATX LGA1151 Motherboard
Memory: *G.Skill TridentZ Series 16GB (2 x 8GB) DDR4-3200 Memory
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive
Storage: Western Digital BLACK SERIES 1TB 3.5" 7200RPM Internal Hard Drive
Power Supply: Corsair 850W 80+ Platinum Certified Fully-Modular ATX Power Supply
Optical Drive: ASUS USB 3.0 External 12X Blu-Ray Writer
https://linustechtips.com/topic/472588-need-help-for-full-pc-watercooling/
Motherboard is too over the top, get one around $200-300 and you can spend more and get higher quality parts for your custom loop.
GPU - 2x GTX 970 g1 gaming (sli) CPU - I5 4690k 4.6Ghz Cooler - Kraken x61 PSU - Corsair ax760 RAM - 32gb Corsair vengeance pro 2400mhz Storage - 730 Series SSD 240gb Case - Phantek enthoo pro
I just finished building my water loop, 3 240mm rads, 6 SP120 fans, 1 CPU block, 2 GPU blocks, and a pump/res combo, and a bunch of fittings cost me about $700 USD. It adds up pretty quickly.
My current Rig (Memphis) --> http://pcpartpicker.com/p/jQYWpg
okay ill see which one I can use then.
around how much would a high quality loop cost?
It can vary, usually though if you're cooling a high end gpu and cpu it would probably be at least $400+ it shouldn't be too crazy though as it's a single gpu so you save a good bit not having to do 2.
Yea, that motherboard is a bit too overkill in my opinion. You could go for the Asus Maximus VIII Hero and still have an amazing motherboard whilst saving money. That saved money can be allocated to your custom loop. Give me a few minutes and I can compile a list of watercooling components that would be compatible with your system. The only thing I cannot guarantee is radiator compatibility with the InWin 909, but I'll try my best.
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
Do I need like a radiator for each part that im cooling? and in the InWin 909 you can fit a 280mm on the front (35mm height max), 240mm on the bottom (35mm height max), 120 by the cpu area (35mm height max)  and a 360 on the back (60mm height max) by the way is this even a good case? i have not sen anyone with an inwin 909 using it as a normal case only mods for shows it looks good but if there are any other cases that have a lot of glass and look nice  and good for water cooling please feel free to tell me
okay well i guess ill go wiht the hero viii. as that guy recommended. i currently have hero vii and i love it
