So my TV HDMI inputs are 2.0 however I am getting squashed images (not full, 1080p, HD 3D) when viewing 1080p 3D content on my PC.
Could this be because my R9 280X is HDMI 1.4a only?
Gaming PC: Case: NZXT Phantom 820 Black | PSU: XFX 750w PRO Black Edition 80Plus Gold (Platinum) | CPU: Intel Core i5 4690K | CPU Cooler: BE QUIET! Dark Rock Pro 2 | MB: ASUS Sabertooth Z97 Mark S | RAM: 24GB Kingston HyperX and Corsair Vengeance 1866MHz | GPU: MSI R9 280X 3G | SSD: Samsung 840 Evo 250GB | HDD: 9TB Total | Keyboard: K70 RGB Brown | Mouse: R.A.T MMO7
Laptop: HP Envy 15-j151sa | 1920x1080 60HZ LED | APU: AMD A10-5750M 2.5GHZ - 3.5GHZ | 8GB DDR3 1600mhz | GPU: AMD  HD 8650G + 8750M Dual Graphics | 1TB SSHD
https://linustechtips.com/topic/469914-3d-problems-with-tv-gpu-related/
Ummmmm....
IIRC 1080p3D is two 960x1080 images or 2 1920x540 images so whatever AMD's 3D technology is isn't properly configurated.
Main PC: i5 4590 @ 3.5 GHz ♦ RX 480 Armor OC ♦ 16 GB DDR3 ♦ GA-Z97-HD3 ♦ 120 GB 840 EVO ♦ 120 GB Intel 520 ♦ W10 Home
Scrapyard PC: Xeon X5460 @ 3.8 GHz ♦ HD 7870 ♦ 8 GB DDR2 ♦ GA-P35-DS3L ♦ 80 GB Intel 320 ♦ 160 GB WD Caviar SE ♦ W10 Home
Ummmmm....
I'm not using any AMD 3D technology just the game default technology and my TV's tech. :S
It's only on my PC that the content becomes squashed.
Care to explain please?
As I understand it the maximum 3D resolution of HDMI 1.4 is 1920x1080 24hz whereas HDMI 2.0 is 1920x1080 60hz.
Since I am runing content at 60hz the resolution drops?
That's probably your problem. 1.3 supports 1080p3D if I remember correctly.
Yes, that's what I figured. I only linked you to the article because I wasn't sure if you had 1.4 or 1.4b.
Ahh right I have 1.4a :( Guess I'll upgrade my GPU soon as well as my PC :P
