hi, i'm looking to change my current case, i need a silent, with dust filters and smallest possible (mATX)
while in search i found this: http://www.coolermaster.com/product/Detail/Case/full-tower/silencio352.html
does someone have any opinion about?
this is my current setup: http://nz.pcpartpicker.com/user/Jerico64/saved/2bSL
here a pic of my current one: http://img801.imageshack.us/img801/7008/nurh.jpg
due to the smaller size do i will have to manage cooling?
sorry for my english and i look forward for any suggestion!
Jerico64
https://linustechtips.com/topic/46974-changing-case-looking-for-suggestions/
Bitfenix prodigy? Always love the look of that.
CPU: i5 3570k                                 PSU: CX650 Corsair                 SSD: 128GB Samsung 840
RAM: 16GB Corsair Vengeance     Case: Zalman Z11                    HDD: 500Gb Toshiba & 1TB Western Digital
MOBO: ASrock Extreme 4 Z77        GPU: GTX 770
Cooling will be fine, check out the Fractal Design Core 1000 and the Fractal Design Arc Mini R2.
The prodigy is m-ITX, he would need the Prodigy M.
Core 1000 is discon.
Man, that sucks. You can still buy it on Amazon though.
Thank you! i had a look at all of them, i like the size of the Core 1000, probably i would go for that (anyway i need a small case)
any other with dust filters? the place in wich the case woud be has quite fine dust from wood and fabric not a crazy amount but i fear that would create problem.
online i read about "positive airflow" how do i obtain that?
