Double wire sleeving help.
Solved by alpenwasser,
I was wondering if it's possible to remove one of the 6+2 pins and convert it into a single one?
Just to make sure I understand correctly:
You have this:
PSU-------------6+2pin---6+2pinand would like to remove the second 6+2pin to make it look like this:
PSU-------------6+2pin?
As long as you still have the right pinouts on all the plugs (correct voltage wire connected
to the correct pins) there shouldn't be any problems with that. Just make sure you don't exceed
the maximum current load for the individual pins in the plugs and you should be fine.
EDIT:
According to Molex, a Mini-Fit Jr. pin can carry up to 9 A, so you should be fine.
