Weird Fan way?
Go to solution Solved by olback,
I prefer the fans to use the Air inside the PC for good Airflow, it makes like a 0-1°C diffrence.
Hi there!
I have an important question: Is the fan for the water cooling facing the right way? Now the airflow in my pc is going in at the front and out at the back! for the radiator for my water cooling is facing outwards so the hot air inside my pc is used to cool the water but inside my pc it isn't like "cool" it is hot there so I ask this to you: Is my fan supposed to get the air from outside the case and blow it trough the radiator and in my pc!?
Windows 10 | GTX 970 | AMD Ryzen Threadripper 3960x | 128GB Ripjaws V
https://linustechtips.com/topic/454373-weird-fan-way/
Generally, people use the air that's in the case. You get slightly better GPU temps and power delivery temps, bc those can get pretty hot.
My rig: Intel Core i7-8700K OC 4.8 | NZXT Kraken X62 | ASUS Z370-F | 16 GB Trident Z RGB 3000 (2x8) | EVGA 1070 SC | EVGA SuperNova NEX650G1 | NZXT H700 | Samsung 250GB 850-EVO | 2x 2TB Seagate Barracuda HDDs
https://linustechtips.com/topic/454373-weird-fan-way/#findComment-6095426
Hi there!
It will be fine to use the air from inside the case so long as you have good airflow in your case. If the airflow is poor and the temp inside your case is hot you will just be using hot air to cool your coolant meaning you will be reducing the efficiency of your radiator quite a bit. If your airflow is balanced well enough the difference in temp will be negligible.
Chernobyl
AMD FX8350 @ 5GHz | Asus Sabretooth 990FX R2 | 16GB HyperX Savage @1950mhz CL9 | 120GB Kingston SSDNow
EK AMD LTX CSQ | XSPC D5 Dual Bay | Alphacool NexXxoS XT45 240mm & Coolgate Triple HD360
Kraken
Intel i5 4670K Bare Die 4.9GHz | ASUS Maximus VII Ranger Z97 | 16GB HyperX Savage 2400MHz | Samsung EVO 250GB
EK Supremecy EVO & EK-MOSFET M7G  | Dual 360mm Rads | Primochill CTR Phase II w/D5 | MSI GTX970 1670MHz/8000MHz
Graphic Design Student & Overall Nerd
https://linustechtips.com/topic/454373-weird-fan-way/#findComment-6096071
