Hi there,
I have a GTX 970 but it has a pretty boring cooler design and I think that it could look a lot better especially because my case has a window,
Does anyone know if it's possible to buy an aftermarket cooler? I do like the look of the NVIDIA reference cooler design that glows up green on the Geforce GTX logo but I don't think they sell them separate and that would mean actually buying a new card which is not what I'm looking for.
Does anyone know any good coolers that i could buy that would look a lot better in my case and maybe give me better temperatures?
I know the Artic ones have issues with the VRAM overheating due to not having good contact so that has put me off it.
Any help would be appreciated.. thank you :)
Here is my current card and what it looks like in my system:
PalitGTX970
WP 000020
CPU: Intel Core i7-4790K | GPU: GTX 1080Ti | Case: Corsair 750D Airflow | Motherboard: ASUS Maximus Formula VI | RAM: 16GB Vengeance Pro | PSU: Corsair AX860
SSD/HDD(s): SAMSUNG 850 EVO 120GB, SAMSUNG PM830 256GB, SEAGATE 6TB | Optical Drive: Sony Optiarc AD-5280S CB-PLUS
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/
No one sells the coolers from what I know, though asking around the smaller system builders doesn't seem like a terrible idea. CyberPowerPC, IBUYPOWER, Digital Storm, Falcon Northwest or Origin PC may be able to help. I don't know that it would even work though since that card does not have a reference PCB (it's too short.)
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028341
Yeah I'm aware that the PCB is pretty short which sucks, But it's worth asking, It just looks pretty dull, I have actually considered buying a new card but then I would have to sell mine and have no GPU until i got a new one :(
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028358
BestBuy is your one and only place, if they still sell them.
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028360
The bigger deal with cooling a GPU with an aftermarket cooler is the VRMs, not the VRAM, just to add. The card you have already has a dedicated heatsink for the VRMs, so if you could find a downdraft cooler that would fit over it and deliver fine airflow to it, you should be fine. There are a few aftermarket coolers out there worth considering, including the Raijintek Morpheus (though I'm not 100% sure if it is compatible with 900-series cards) and the Arctic Cooling Twin Turbo III.
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028370
It was quite a while ago when i did the research on the Arctic coolers but i knew there was some sort of cooling flaw somewhere which put me off buying one, Do you know if the Twin Turbo III has the same issues by any chance?
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028399
I'm from the UK unfortunately so that would probably not be an option for me  :lol:
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028403
Maybe an AIO bracket and corsair H55/H60 might do the trick.
CPU-delided i5-4670k@4.6Ghz 1.42v R.I.P (2013-2015) MOBO-Asus Maximus VI Gene GPU-Gigabyte GTX 970 G1 Gaming@1582Mhz core/3744Mhz memory COOLING-Corsair H60 RAM-1x8Gb Crucial ballistix tactical tracer@2133Mhz 11-12-12-26  DRIVES-Kingston V300 60Gb, OCZ trion 100 120Gb, WD Red 1Tb
2nd  fastest i5 4670k in GPUPI for CPU - 100M
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6028903
Could alwasy ship you one though it wont be cheap :P
https://linustechtips.com/topic/449627-gtx-970-reference-cooler/#findComment-6050757
