Keyboard shortcut issue.
Go to solution Solved by Naeaes,
Plug in a USB keyboard. If it's a software issue, it'll likely replicate on the other keyboard too. This could obviously be caused by a short. you can access the cables by removing the keyboard. If unhooking the mouse cable fixes the issue, you it's a short in the mouse.
So, I am reimaging a machine for my cousin, a VIT M2400, (Venezuelan Institute of Technology) and am running into a strange issue. Everytime you hit the 'R' key it brings up the right click context menu. I'm fairly sure it is a software issue, but I don't even know how to begin diagnosing this.
If you have ideas or information I should find and post, any help would be appreciated. Thanks!
vSphere Cluster - 72 Cores - 512GB Memory - 6TB SSD RAW - 42TB HDD RAW - vSphere 7
resonance - Dell PowerEdge R730xd - 2x Intel E5-2667 v3 - 128GB DDR4 @ 2400MHz - NVIDIA RTX 5000 - 2x250GB Samsung 870 Pro - 2x1100W 80+ Plat - ESXi 7.0U3
kat - Dell PowerEdge R630 - 2x Intel E5-2690 v3 - 256GB DDR4 @ 2400MHz - NVIDIA TESLA P4 - 500GB PNY SSD - 4x1TB Crucial SSD - 2x750W 80+ Plat - ESXi 7.0U3
starlifter - Dell PowerEdge R720 - 2x Intel E5-2650 v2 - 96GB DDR3 @ 1333MHz - 2xNVIDIA GTX 970 + 1050Ti - 500GB SSD - 7x6TB HGST HDD - 2x1100W 80+ Plat - ESXi 7.0U3
ion - Dell PowerEdge R620 - 2x Intel E5-2650 v2 - 32GB DDR3 @ 1333MHz - NVIDIA QUADRO M2000 - 2x250GB Samsung 870 Pro -2x750W 80+ Plat - ESXi 7.0U3
Main Rig
Intel i7-5820K @ 4.6GHz
MSI X99S Krait SLI Edition
32GB Crucial Ballistix Sport DDR4 @ 2400MHz
Aorus GTX 1080Ti Waterforce Xtreme
Intel 280GB 900p
512GB Crucial NvMe
512GB Samsung 860 Evo
EVGA Supernova 850 G2
Thermaltake Core P5
https://linustechtips.com/topic/445945-keyboard-shortcut-issue/
https://linustechtips.com/topic/445945-keyboard-shortcut-issue/#findComment-5977065
Nice, I'll do that right now.
Main Rig
Intel 280GB 900p
512GB Crucial NvMe
Thermaltake Core P5
https://linustechtips.com/topic/445945-keyboard-shortcut-issue/#findComment-5977091
Okay, so it won't detect the USB keyboard, but it does detect the mouse. The left arrow key and the 'F' key both execute those functions at the same time, and the Context menu key and the r key both execute both functions at the same time.
Main Rig
Intel 280GB 900p
512GB Crucial NvMe
Thermaltake Core P5
https://linustechtips.com/topic/445945-keyboard-shortcut-issue/#findComment-5977135
Okay, came up with a working solution.
From what I can tell, I got a USB keyboard working, and it doesn't replicate the issue, so I believe this is an electrical issue.
I downloaded keytweak and disabled the arrow keys and the context key and now they do not type the same, but interestingly, the left arrow key still types an f and the context key still types an r. But she is not an advanced user and used the mouse for most everything, and what is important is the capacity to take notes properly. So this solution is workable at least!
Thanks Naeaes
Main Rig
Intel 280GB 900p
512GB Crucial NvMe
Thermaltake Core P5
https://linustechtips.com/topic/445945-keyboard-shortcut-issue/#findComment-5977372
